A few weeks ago I broke one of my shocks that I purchased from Roe Racing. They are Koni modified with an adjustable purch. The purch on my right rear shock worked loose,the shocked bottomed out,pushed all the fluid out and cracked the housing.(I failed to tighten it properly) I called Sean to see if he had a replacement on the shelf. He did not but directed me to Kevin at True Chioce to repair my shock. The problem was I had signed up for a track event at Putnam Park the following week end. Sean actually sent me a shock from his shop car to use while my shock was being repaired!!! Wow!!! Now that is a stand up guy!!! Thanks Sean! And special thanks to my crew chief Steve Fess!
