tunning 08
CitySnake
Manhattan, USA
I've tried extra "n"s to no avail. (Sorry, j/k)
Other than headers and exhaust, there's nothing available....yet (as far as I'm aware).
Nader
New York
mark mentioned in another thread that the mopar performance tuning has been developed but not available as of yet.
ACRBruce
Socal
Spoke to an Mopar engineer yesterday at SEMA about the ECU and he said calibration is almost done and they are just finalizing the specs. He said they will release the information soon and just keep an eye out here in this forum. I was trying to get an HP number out of him but he wouldn't say much of anything else.
Omaha NE.
You won't be disappointed with the numbers especially considering the price.
Flyntgr
Franklinton, LA USA
When do they expect to have the ECU calibrations? Will this be something we can have done to our own ECUs, or do we need to either: (1) send off our ECUs to Dodge, or (2) buy a new ECU with the tune already made? Thanks.
Omaha NE.
With the problems associated with an off road only "flash" I'm sure you will be purchasing a new PCM programmed with the changes. This will insure that the tune is sold as a non CARB approved part. Remember though the new systems in the Viper will remember that this change has been made so even if you switch it back there may be a record stored somewhere in the cars on board software. If you have an ACR this will likely not be an issue because the warranty is so thin anyway ;).
If you are using this with the Belanger headers the results will be even greater than without the tune so maybe we will see a 90+ hp gain? That would be OK wouldn't it? :headbang:
vincy
Baltimore, MD
Mark, how does this work? Can the dealer install a new Mopar tune? Thanks.
Edit: I see you answered this above. When can we expect to get this? Put me on the list. Thanks
rcl4668
Oregon, USA
Mark --
I know you can only report preliminary information but I am assuming this ECU upgrade will be for "off road use only" as with the 2003-2006 Viper Mopar ECU upgrade. What real-word impact is there for a consumer? For example, my Belanger header and exhaust package is also designated "off road use only" by Lou Belanger but so long as the system continues to throw no codes/CELs, my local Department of Environmental Quality does not care in terms of emissions testing. Likewise, my local Dodge dealer is, like you, fairly mod friendly and this has not been an issue. Any hidden pitfalls you are aware of other than a potential warranty issue?
Likewise, do you have any information as to whether the new 2008 ECU upgrade will result in a CEL? Also, will the ECU upgrade deactivate the A/C system or other functions in the car like the 2003-2006 ECU upgrade?
Thanks for your feedback.
/Rich
fastmd
North New Jersey
Mark,
Give me a call or send me an email when it is done. I would like to see what it does to the beast you built me.
Fast1
Phoenix, AZ
How does the +90 hp with PCM upgrade and Belanger exhaust relate to the theory that the 8.4 is maxed out at 600 hp and any performance modifications need a piston swap? I have heard that the pistons are the weak link. My opinion is that horsepower does not affect the pistons as much in naturally aspirated conditions as it does in forced induction applications, but i was wrong once before. Does anyone else have any first-hand information on the '08 strength reliability/issue? I know that they are the same pistons that are from the 6.1 Hemi. How can they be weaker than the '06 pistons if they are both hypereutectic (spelling?) anyway?
I hope this is not opening up a whole can of worms, but I just want to try and get a true assessment of the '08 block and internals prior to modifications.
Omaha NE.
You are correct Rich that the off road designation will be the same as the previous unit. I have been told that all the functionality of the stock controller will remain and only the upgraded programming is changed so no CEL and no less user features.
Mark --
/Rich
Omaha NE.
The engine will be just fine at the increased power and is a very stout package overall. The rest of the drive train will notice the increases though and things like transmission and diffs may end up being the weakest points. Only real world time will tell but they are confident it will be OK. Swapping the pistons will be needed if we ever get to the forced induction of the new motor but at the 650-700 range you will be just fine.
cheryl mccally
Mark will these new ECUs give an additional boost above the Belanger's and if so how much can we expect and about how much will it cost?
cheryl mccally
Mark will these new ECUs give an additional boost above the Belanger's and if so how much can we expect and about how much will it cost? I see you already answered this question, so we can expect about an additional 20 hp increase above and beyond the Belanger system, right? I want one as soon as it comes in, put me on the list too!
Omaha NE.
Got you covered Cheryl :D
MKB96Viper
Oviedo, FL.
Mark,
Do you know if the new software will remove or at least move the preset torque management number far enough up so we can utilize some small power adders like 100 or 150 shot of nitrous? If not, can you please request that or at least bring it up for discussion?
No one has been able to crack the stock ECU yet so power adders are out of the question so far for the 2008. Thank you for your help.
Omaha NE.
Mark. Will it improve throttle response ??
Yes the throttle response concern has been addressed.
Mark,
I will check on this but I would first think NO since this is in place to protect the rest of the drive train from damage. I will check though and post back.
sounds great put me on the list and let me know when it is available.
Done, thanks.:D
Fast1
Phoenix, AZ
Sorry to beat a dead horse, but how did this weak motor rumor originate anyway? I thought it came from from session from the SRT engineers directly? Did they change their mind?
I'll take one also!
How long until expected release date?
Omaha NE.
After talking with the SRT group today I can tell you that there is NO torque management software in any of the 08'-09' cars so they do not need to remove it. The thing you are feeling is the fact that you have whacked out the sensors by pushing the NOS into them. They work within the limits set by SRT and the new Mopar PCM will have extended limits that may or may not be enough to allow a small amount of juice.
Mark,
