What is the best radial slick to run
KC
Tucson, AZ
I was thinking about kumho ECSTA V700, ECSTA V710,VictoRacer V700
FrankBarba
These are not slicks. They are classified as DOT tires.
K
KC
Tucson, AZ
YesI know I want it to be street legal I'm looking for the best street radial I can go to the drag stip with without changing my tires. I dont have a extra set of rims
Jack B
NE Ohio
I have run the MT ET Drag Radials all summer. They are about as good as it gets for a street slick. The problem is you will need a set of 16" rims. If the track is not prepped you will be dissapointed in the Kumho's, on the other hand they are an improvement over pilots. Nitto makes a street slick that you can put on a set of front wheels.
YELL03
Bucks County, PA
Kumhos Ecsta V700s are what you want.
On Michelin Pilots my Viper ran <a href="mailto:[email protected]"&gt;[email protected]&lt;/a&gt; with a 1.89 60' on a 2000rpm launch. I could not even go WOT on the 1-2 shift without going sideways.
Put on Kumhos.
Launched at 3500rpm once with no wheelspin and ran &lt;a href="mailto:[email protected]">[email protected]"&gt;[email protected]&lt;/a&gt; with a 1.89 60' on a 2000rpm launch. I could not even go WOT on the 1-2 shift without going sideways.
Put on Kumhos.
Launched at 3500rpm once with no wheelspin and ran &lt;a href="mailto:[email protected]</a> with a 1.68 60'.
% other runs were all launched at 2000roms, all 1.8 60's, and all runs were 11.8 (3 times) and 11.9 (twice) on Kumhos - all at 120+.
Take my advice, for $241 each at Tire Rack they are a steal.
Howard
99 R/T 10
Enterprise, AL USA
If you want maximum traction, the BFG drag radials are the best. I have heard of them being used on the street, but I wouldn't do it due to the sofe sidewalls on the tire. I use my BFG's on an extra set of rims, but if you don't want the hassle, go with V700 Kumhos.
ViperRichRT10
Suwanee, GA
This is a easy question. If you are going to use the tires for street and track, go with the Kumho V700. They stick like glue and have good sidewalls for cornering as well. They grip like hell and I have a SC car. If you are going to use for track ONLY, the BFG are a little stickier but sidewalls ****. Not good for street at all! Best bang for the buck is definitely the Kumho V700 IMO!
Rich
VIPER D
dutchess county, ny
bfg drag radials 345/35/18 are the only way to fly
vd..
Chuck 98 RT/10
tampa, fl USA
I had a set of those BFGs. Pretty radical looking. I sure would have liked to have dragged them, but I would have fried them up and then I wouldn't have been able to sell them, not to mention I probably would have busted a halfshaft or worse.
tbone96
