19" Rears rub on arches.....before lowering springs...!
PS78
UK
2002 RT/10
with 1/2" lowering caps
Just changed to the new Forgeline GA3Rs with 345/30r19 PS2s and getting contact on the rear arch tops...
Aiming to get stock shocks stiffened to 1.25 turns etc (as detailed elsewhere on VCA) but, with a set of eibach lowering springs eagerly awaiting fitment, my questions are:
how am i gonna stop the tyres rubbing, once the spring are on and the original caps are back in (i.e. car to be lowered further 1/2")???
how much stiffer are the lowering springs beyond stock and is that sufficient to stop rubbing on a viper 1" total lowered, with 19" wheels?
Have read on the forum of owners lowering by 1.5", with obviously larger dia wheels - how?!
is body panel shaving/ widening, etc required?
Red Snake
NashVegas
You are going to have to run a smaller diameter tire.
Those of us with 20" wheels have a similar delima. PS2s come in 335/30/20 and they will usually scrub on a lowered car (and a lot of stock height cars). Most run the 345/25/20 Nitto Invo which does not rub on a lowered Viper.;)
PS78
PS78
UK
smaller apsect ratio? have been hunting for
335/25r19 (tyre wall= 84mm) or
345/25r19 (86) - don't seem to exist!...only
355/25r19 (89...still less than the 104 on the 345/30r19!)
wonder if there's any significant additional clutch stress when fitted with the 355s.....?
Timnineside
West Michigan
I run the 345/25/20 Pirelli's and only rub when the tank is full and hit a huge bump while having two people in the car.
And my car has the Eibach lowering springs with caps. So you must have some big O' tires on that thing!
PS78
PS78
UK
well....no?...just the 345/30r19s....
are the eibachs stiffer just to compensate for the 1" lowering result, or are they stiffer still to further resist chances of contact?
PS78
PS78
UK
well eibachs on now (so total now 1" lowered - original caps back on) and front shocks set .5 turn back from full stiff, rears: 1 turn back
not as much rubbing as before but still happens...
PS78
PS78
UK
will try increasing the shock dampning to full stiff & .5 back.... then if not working, onto stiffer springs...
Viper123456
