92 Using Oil / Part-2 / My Story!
FRANK
Somewhere in southern NJ
Al,
You sound like my type of guy...forget messing with it and rebuilding the whole thing...keep it simple...and cheap! Kudos to you...
Viper Wizard
South Salem, NY USA
YES YES oil is cheap!-"Jeff"
Drive it half throttle for a while and see how much oil you use?
I now it wont be easy!
If you don't need it I'm not going to do it!
Thank You Al.
F
FRANK
Well...
Check your oil often. See if it is thinned out and smells like gasoline. Keep a CLOSE eye on it. If it reeks of gas and is thinned out then there will be problems. I'd try this approach before I spend a dime! If it doesn't cost anything why not try it?
Jeff Torrey
Plaistow, NH USA
Good- Lets see where this thread goes. Al- You are the reason I did not worry at first. But the car uses 3 quarts every 500 miles.
I do not want to blow the engine.
I do not race the car.
F
FRANK
If you can't smell it you should be able to feel the thickness of the oil on your fingers. If it is thinned out you will be able to see it.
