Really hoping someone can help me with this. Was driving fairly aggresively at highway speeds, dropped a gear coming off the ramp and it just quit. Found the big 20 amp PSM/ASD fuse blown. Put in a new one and it started right up. Was driving it home and all was fine. ****canned it coming onto the freeway and it happend again. Seems if you take it easy its fine but as soon as you give it some it blows this fuse. Ive have the car on blocks this evening and looked everywhere top and bottom for a severed wire. Figured something was touching a header or something. Took the crank sensor heat shield off and inspected that. Looks fine. Even went so far as to have it running on blocks and wiggled every wire I could find in hopes of replicating the issue in the garage. Im stumped. It appears by reviewing the manual its somewhere in the ignition system. Thinking maybe its got something to do with this automatic shutdown system. Perhaps I should change the relay?
Any thoughts would be greatly appreciated.
