Alternator Fuse?
Suerteviper
Could someone please tell me where my Alternator fuse is located in my 2001 RT10 Dodge Viper?
I disconnected and reconnected the positive Battery connection under hood, now Alternator not charging the battery...any suggestions for me??????
Jack B
NE Ohio
I believe the Gen II has an inline link in the alternator harness. Have someone with the manual locate it for you or call Chuck Tatar.
Hi Suerteviper, It is referred to as a “Fusible link” The Fusible link is between the Main Lug on the alternator and the Power Distribution Unit (PDU)
Also, check the Battery Ground located at the left rear frame rail from the battery as this will cause charging issues as well...
Hope this helps
Daveg..
bluesrt
the fuse link may look ok to the eye, find it and lightly pull on it from the wire,it may stretch apart
