ARP head stud Torque???????????
ViperTony
Try contacting Dan at ViperSpecialty as he sells these.
99TURBO
the tech arp said if you use their thread sealer (Part # 100-9904) torque to 86ftlbs and if you use other thread sealer (motor oil) 126 ftlbs
2001 gts what did the box say?
fe4snake
Florida
99Turbo is correct, that is exactly waht I did for mine! :2tu:
Cape Coral, FL
As per ARP, the "insert" that comes with Studs always superceeds the box. The Insert states 86lbs w/Moly lube. However, we always torque to 100 w/Moly, and have never had an issue.
monoman2345
