SoCal Rebell
Well its been 2,200 miles since I got back my 00' RT from Arrow and here is an update, changed the oil after 200 miles so in the last 2,000 miles I have burned only 1 quart. I wanted to know what exactly was done and get a report from Arrow only to be told that was not possible, well finally after a little nagging I got a three paragraph report from Arrow which consisted word for word of the following:
Invoice # YV603104
Powdered metal cylinder liners may have been the cause of high oil consumption the customer reported. The block was returned to the original manufacture for liner replacement and re-decking (does this mean I have a higher compression?)
The engine was rebuilt using all new parts such as a crankshaft, camshaft with lifters, piston/rod assemblies, timing chain set, two exhaust valves, one intake valve, water pump, rod/main bearings, gaskets and seals.
The engine is then sent to our dyno facility for a two hour break in period and three W.O.T. power runs to confirm the engine meets rated h.p. and torque #s. A cylinder leak down and and compression test is performed, with an inspection of a special oberg oil filter and a final check for any external oil leaks, the engine is readied for return shipment.
Pretty cool stuff, I have a new engine after 10,000 miles, and it goes to show if you push hard enough you will get the info.
Invoice # YV603104
