Achilles99
Question:
I have 63 pound injectors. According to the VEC2 instructions, I should set the base fuel calibration to 30(GenII)/63 = 47%. However, my car currently has 55% on it (from a previous tune done by a well-respected tuner who shall remain nameless for now). I am throwing a "Bank reports rich condition" engine code. That means that I have the base fuel calibration set too high, right? IE, in closed loop (throttle < 80%) the PCM is having a hard time with the fuel adaptives?
If I change it to something lower, will that throw off the open loop fuel and ignition maps entirely off? Right now, after installing a WBO sensor, I'm running pretty lean (12.5-13 at WOT). I'm afraid that if I change the base fuel calibration to something leaner to help prevent the check engine light (which I assume is triggered during closed loop mode), I'll be changing my open loop fuel and ignition maps. So, perhaps I should bump that up a notch as well all across the board? Let me know what you think, thanks!
