Battery Tender question for 09 ACR
Shad0w
So Im looking for a battery Tender for my 09 ACR.
The car is parked in my garage for the winter and I do have access to power...
Which Battery Tender would be best? I noticed there's a bunch of models.
tiger6
A number of alternatives on the market. I've had good success with Ctek.
Shad0w
I was actually looking at the "Battery Tender" brand. What curious which one ppl are using most often here :)
SSGNRDZ_28
Indianapolis
I'm using the battery tender plus. It is better suited to charge a battery vs. the Jr. which seems to be mainly used for maintenance.
SSGNRDZ_28
Indianapolis
Yes that one you linked to. There are many models, the main difference is voltage and current output, number of banks, and international vs USA models so you can **** out many of them.
You'll want a 12V model. The JR is meant for maintenance (low current output), there is also the waterproof model with higher output.
lpjr
I use the Sears Battery Charger/Maintenance unit fastened to the wall near the rear of the car. I installed the quick connect plug on the battery and the cord from the charger stays attached all the time with the deck lid closed lightly {no pressure on the wire}. The unit stays on 2 amp trickle charge and only turns on as needed. I have the Sears Platnium Gel type battery. Hope this helps.
larrt
1bad540
also have a ctek, have used it on my bmw, vette and the viper and never had an issue.
CEJ
Raleigh, NC
Been using the Battery Tender Plus (1.25A) for many years now. Also bought a Battery Tender Jr for the generator and lawn tractor. They work well.
Garron
I have a ctek on one car and battery tender plus on the other. both have been great
Shad0w
Thnx guys, picked up the battery tender plus, got it hooked up to the ACR :)
Appreciate the input!
No members online now.
fatmatta
