Bypass the heater core
bluesrt
may not be a good idea. do it and see if it runs a little hotter.some need the core-some dont for proper cooling---
Martin
Why are you looking to bypass the core? It shouldn't hurt anything. I've bypassed plugged up heater cores before just so that I could pour a bottle of CLR in them to break up all the junk that accumulated over the years. Never noticed anything working any different during the process, other than the heater worked a lot better after all the gunk was cleaned out.
bluesrt
feel both hoses closest to the core,if plugged they will be considerably differant temps
Martin
Another thing to try is to run a garden hose through it in the reverse direction of the normal flow and see if water flows easily. A bunch of gunk will also probably come out... On my Gen II, the valve broke in the closed position a few years ago and that made me think I had a plugged core because the heat wouldn't work. Those valves are pretty wimpy.
countourcafe
