Carter Fuel Pump Module
s55c
So I'm talking about Gen 1, in particular mine is a 1995.... a lot of us know about the fuel sending unit issue,,, I was curious if anyone who might have used one of the Carter units found that it cured the problem OR is it just as screwy as the OEM???? Am going to be changing my sender,(pump wks fine),,, I have both a Carter unit and a mopar sender... and since its such a PIA I really don't wanna do this again - so was looking to see which one works better,, not a lot of faith in the mopar one. Thanks
Dan Cragin
LA, CA
Carter is the same as the Mopar (fuel pump module). You can change only the sending unit.
