CEL/MIL - Check Engine Light Question & Codes
Guy
Europe
I've been having trouble with an O2 sensor that never really threw a "check engine light", except one time on a short drive. It has since been replaced, but I was reading up about the CEL/MIL function and have a question (or two)..
When you turn the key on your Gen-3 all the way on, it it normal for the CEL to stay on? When I performed the "on-off on-off on-off on" trick, it blinked 11 times. To the best of my searching generic OBD-2 codes, that means "no fault".. Is this normal? The CEL is off when the car is started and running.
Does the Gen-3 display in the odometer area a Pxxxx code when one exists? I have a Craftsman OBD-2 scanner and used that the time the CEL came on, forgot to try the on-off trick..
Thanks!
Guy
BLK04
New Brunswick ,Canada
cycle the key to the on position 3 times & the odometer will give you the trouble codes , if none there it will read "done" when you leave the key on without the engine running the light will stay on because of no oil pressure ...
No members online now.
JpKL
