Differential pinion position
jpierson
While measuring a '96 R/T10 differential frame section for fit in a chassis I'm building it looks like the pinion centerline is positioned about 11/16" to the passenger side of the centerline of the frame section the differential is mounted in. Is this correct and, if so, is the engine/trans mounted off center in the Viper chassis?
viper2002
