factory alarm question
22YRSOLD
why does the car alarm trip. i turned the car off. then decided to go park it. when i went to turn it back on it started and turned of right away. then u see the alarm light flash. so i sett the alarm off so i can turn on the car. so i press the unlock button and try to start the car and it does it again. so i wait 5 minutes and it was back to normal. is there a reason why this happens or is it just the viper....
Randy
Earth?
Sounds like a Gen I Viper, and not getting the alarm disabled? However, opening the door should have set it off, so not ringing a bell with me a common problem.
22YRSOLD
Yes it is a 94. i did open the door to put my top on. when i got in after 5 minutes it started. So is that what you got to do?? just open the door?
trainville
Oregon
Try replacing the batteries in your fob. That's a cheap place to start and maybe it's running out of juice. The factory alarm has a fuel-interrupt which will allow the car to start, but then it quickly dies (when alarm is activated).
I'd check the $5 battery first. Good luck,
Mpcc
