first oil change.
luc
Paso Robles CA
Changing the oil yourself is very easy on a Viper.
Beside saving good money,10 qts of mobil 1 and a filter will run you about $55 compared to $120/$150 at a dealer,you learn about your car,are sure that it's done correctly and doesn't have to be dependant one someone else.
If you need any tips/infos, just ask.
Welcome to the Viper Nation.
Luc.
Ulysses
San Diego, CA. USA
Luc is right, it's easy to do yourself and you learn about your car better. But there is an advantage to taking it to the dealer for the first few and that is so they can check the car over for anything that may have jiggled loose, leaks, etc... that might occur and that you aren't aware of yet since you are a new owner. After all, even though it's a hand assembled low production car, it's still a production car, prone to human error and sh*t happens. Plus, these guys are very knowledgeable and you can talk to them about the car and it's workings while they work on it.
tradingkekhiladi
