FOR SALE: 36 lb/hr injectors (40 lb /hr at 55 psi)
Simms
Pittsburgh, PA
I'm putting them in the classified section.
I have a brand new set of 36lb/hr injectors for sale that I did not use with my Roe setup. The injectors are commonly used in Ford Motorsports, made by Bosch, High resistance, flowing 36 lbs / hr at 43 psi.
Asking $200.
Qualitywires.com
Louisville, KY
Re: FOR SALE: 36 lb/hr injectors
I thought the Roe came with the green top injectors? What are those rated at...sound line the ones you have for sale are the same rating as the bosch green tops...I thought they were 42-43lb injectors.
Simms
Pittsburgh, PA
Mine are actually blue tops rated at 40 lb /hr at 55 psi (36 at 43 psi). They were used in Sean's kit over a year ago, before the Green tops I think.
I upgraded the kit to the black Siemens injectors at 53 lb/hr at 55 psi.
99 R/T 10
Enterprise, AL USA
Blue tops used for the 5 lbs pulley, green top used for the 8 lbs pulley. Is the green also used for the 10 lbs as well? 1tony1?
Simms
Pittsburgh, PA
Thanks Mike. The injectors Sean sent me for my 8lb pulley are all black.
Hope to see you in Florida.
Simms
Pittsburgh, PA
Whaaaaaaa?! That different, mmmmmmmmmmm.
Sean refered to them as "black Siemen injectors at 53 lb/hr at 55 psi."
Now I don't know about all the 8lb kits, but my VEC2 also came with a resistor box for the new injectors. It might be specific to just the new Siemen injectors he is using.
Maybe Sean can further explain.
J DAWG
MS
top fed I assume?
countourcafe
