I would like to start out with thank you for the help guys, but you all happen to be wrong
The fresh air door you guys where talking about was working fine.
All of the acctuators seemed to be work fine as well.
This is what I found.
That is a vent screen that goes in the crotch vent, like this.
It had fallen down into the inside of the heater and was blocking the inside door from closing off the cold air to the AC vents, it also was robbing alot of air flow from the heat vents.
So if you have this problem look into the lower vent on the passenger side, if you dont see this
Maybe your problem is as simple as mine was.
I think this may be a freak thing, it would be strange for this happen like this again but there will be somthing to search fro now!!
My car has had this problem since I bought it, I just thought the heater was crappy (sports car who needs it) but now that it is working correctly, It works great!!
