Help in buying parts for Gts.
The part number that you have provided does not match any Viper from 1992 through 2010 per the Mopar parts catalogs that I can check.
It does match an early Durango, a Dakota, a truck...
You might want to take your VIN to Dodge dealer and try to order the correct part. They may have to search the vintage parts sect I on.
Good luck.
Cat22
Port Orchard, WA
I used the idler pulley from the above mentioned Dodge Dakota. Works fine. It is slightly wider than the belt, but it installs and fits perfect. As for the tensioner not sure if it would work?
