V10 ACR
Hi All,
I'm looking for some input and guidance so the dealer can fix it right the third time. I have a 2000 GTS ACR that has been acting up. When you give it the gas with any type of load, you lose power. I can drive on the highway fine at 70 mph. Sounds good. If I step on it it justs sits there and acellerates very slowly. As soon as I let off the gas, the car will surge forward for a second and then settle down. We thought that it might be the cats, but they check out fine. They already replaced all the O2 sensors and plugs (no help). They are thinking now that it is related to the fuel system. What I was told is that there are two floats in the tank and that one is somehow related to the fuel flow when under WOT. It somehow opens the fule line or activates a second pump? Does not sound right to me. They now want to drain the tank and check it out. I have only used major brand premium gas, I have never purchased cheap gas (but that does not mean that I never got any I guess). Any ideas or suggestions? Thanks.
