Help on gauge pod needed
Yellow Fever
San Diego , CA
Jack , why not do what I did..Pull your battery gauge and drop your boost gauge in it's place :2tu:
The Pillar Pods don't have a nice factory fit.
Cheers
Jeff
RedGTS
Tennessee
The other alternative is to use a single pod mounted on the steering column. There is an aftermarket one made for the Dodge truck that shares the same column that fits well.
Bandit400
Central, NJ
I got my A-Pillar pod to fit good but I had to really heat it up with a hairdryer and mold the top of it to the pillar. Otherwise you will have a large gap at the top. I am happy with the A-pillar pod since I needed two gauges, a fuel and boost.
Bandit400
Larry Macedo
Sanford, FL
We use the column pod, although it takes a bit of manipulation to make it work correctly. Which pillar pod works the best that can be shaped to fit? I purchased a VW pod a while ago and the contour was pretty close at the top, although the bottom was a bit misshapen.
Joseph Dell
Atlanta, GA 30338
I wasn't impressed w/ the ELITE gauge pod. It looks like a mustang pod w/ a viper logo on it.
speaking of which, a mustang gauge pod fits nicely. cheap, too.
JD
