I have a Mopar performance ECU if anyone is intrested.
IDWIN
Windsor, Co
What gains will you see from this on a stock GTS with just smooth tubes and a borla exhaust with hi flow cats?
what would you like to get for it?
Forged Horsemen
South Elgin, IL., USA
I have one in my 99 GTS with T&D rockers,SVS throttle bodies smooth tubes and K&N cold air package,Borla cat back. And I think it helps the engine run a little fatter due to the mods specifically to the exhaust and intake leaning the engine out a little. Just my humble opinion.
Joseph Dell
Atlanta, GA 30338
The biggest benefit of this ECU is that it doesn't check all the things that the newer PCMs check... like the presence of cats, evap canister, etc... so one is more likely to pass emissions with this ECU than they are with a stock ECU.
as for performance gains, i ran two back-to-back dyno pulls without changing ANYTHING on my 99 PCM vs. the mopar performance ECU... the difference in power was, literally, 1hp and less than 1 ftlb of tq.
The car is a little more responsive with the mopar ECU... but i can't explain why. power is the same across the band (with mine).
just my .02...
JD
npeifer
I am interested in it. Does anyone know if it will fit my 96 RT/10 Viper ?
