I need some good alignment spec's for street use...
fe155
San Diego,ca
I need some good alignment spec\'s for street use...
I seem to be fighting the steering and the car wants to follow every crack and uneven surface. Im sure the big tires have something to do with it but im also sure some different alignment spec's would help. Im not so concerned with tire wear as more controlable steering and ease of ride . So any advise , experience or opinions would be appreciated .
SoCal Rebell
Mission Hills, Ca USA
Re: I need some good alignment spec\'s for street use...
I had that problem when I first got my Viper, when I took up roadracing I put on a mild track alignment (for the track) but realized it really helped with the crack problem on the street. Go to a -1.5 front camber and a -1.0 rear camber. The car will handle curves and turns better but will be a little more "darty" but you get used to it.
Caster +6
Toe neutral
SNKEBIT
western wisc.
"by accident" my tire guy ordered the front tires for me and they ended up 1 inch or so narrower. The "rut" problem went away!!!!
Chuck 98 RT/10
tampa, fl USA
Tracking the road is part of the fun isn't it? Agree with Ron on his alignment settings.
