Just another FYI Paxton on Ebay Link.
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
Just a bit concerning ... "the supercharger head unit has a few chips in the blades but it was like that when I pulled it off but it spins freely and I think it is all good. this unit is sold as is".
big-n-italian
Central Illinois
there are ALOT of chips in the blades!
will the chips make a difference? how does that happen - no air filter?
Cape Coral, FL
That looks like Viper D's car in the first picture... wonder if the auction is legit?
blade damage= rebuild time. DO NOT use it as-is!!! If that impeller comes apart, your engine eats it- simple as that! I am not sure what the drive ratio is off the top of my head for the novi-2000, but you can be sure that impeller is spinning many 10's of thousands of RPM's.
Edit... duh, thought impeller... typed turbine. No Turbochargers here...
DMan
Maryland
This looks remarkably like one from just a couple months ago, description is amazingly similar, could be coincidence .. or not. I dunno.
viper04
yeah I tried to buy that pile of parts months ago for what it is "worth"....didn't happen.
Yes I did see it for sale a few months ago, but can you say why it did not happen?? :eater:
SRTLEN
Calgary, Alberta
Thinking about selling the car so I removed the unpolished Paxton kit. It was only on the car for maybe 3 months.
Items missing are the dowel pins for the crank pin kit the fuel lines and coolant hoses are there but may or may not work depending on how you route them.
Comes with upgraded water pump. I have been busy so haven't had time to check into shipping costs. $4650.00 Going to put it on ebay but thought I would mention it here first.
Len
