Lethal 650 Dyno
CNTW84U
Draper, Utah
Here are the before and after on the Lethal 650
from the dyno. An additional 171 hp. Great power
throughout the rpm range.
Good job APEX!
LTHL VPR
Surprisingly, the correction factor was 0% despite the fact it was over 90 degrees when the car was dyno'd; I have always felt like we have a 'conservative' dyno machine. I would have thought the correcion factor would have been something like +2%.
Keep in mind that this car has cats, has conservative tuning for a NA car(under 13.0:1 air fuel everywhere), makes great improvement in power and torque in the low-mid rpm range, and is emissions friendly.
Thanks for your interest!
-Wayne
Eddie N
Bakersfield, CA
i'm not an expert, but isnt 385 hp low for a stock GTS?
regardless, those are some great na numbers..
- eddie -
Anthony, it's quite a detailed list of componentry and supporting hardware. With all the additional power, we upgrade other parts such as the harmonic balancer, timing chain, throttle bodies, half-shafts, airbox, etc. We can also upgrade to an aluminum flywheel and our Dual Kevlar clutch that can withstand over 800hp and 10k rpm.
You can check out our website for more info: www.apexmotorsports.com, then click on the "Lethal Power Packages" button.
If you have any further questions, please don't hesitate to ask!
