Methanol/Water ratio for 8lb ROE
Payne
I recently bought a ROEed Viper, and am almost out of the **** (winter washer fluid), so I bought a 5 gallon drum from my local speed shop.
My question is what is the ratio of distilled to **** for injection?
Sorry to be a boost noob.
Jason
GoCanes1
Nashville, TN
I use 70% ****/30% water and I also have 8lbs. I think the more important part is what the water/**** mix was when it was tuned but I could be wrong. I have always used the same.
Mike
P
Payne
Mike
The car is pig rich on the **** (under 10:1) and will be getting retuned at some point soon. Should hopefully pick up 50rwhp...
Isnt ****/water flamable about about 60% ****?
Simms
Pittsburgh, PA
When mixing methanol with distilled water, is there any other addative the needs to be used? I've always just used washer fluid.
Madduc
Fremont,MI
I believe the correct ratio is 50/50. I buy the yellow bottles of HEET, and mix it with an equal amount of water. Snow Performance sells Boost Juice, which is 49% **** and 51% water. They also sell Nitro Booster which I haven't tried,yet. You could also call Sean and ask for his input.
99 R/T 10
Enterprise, AL USA
If you get the -20 or colder windshield washer fluid(about 35% ****) and ad a bottel of the HEET(yellow), you end up with near a 50% mix.
P
Payne
I'm in San Francisco, its hard to find -20 washer fluid, so it'll be 100% **** mixed 50/50 with distilled.
Thanks guys!
JP
plumcrazy
ALL OVER
doesn't it depend on how the car was tuned ? wouldn't it be based on the mixture at the time of tuning ?
