Need Help on a Eibach springs
YELLOH
Cape Cod, Mass
Hi guys I recently put new wheels 19" in the fronts and 20" in the rears and alot of you guys had responded to my posts saying that you had a much better ride with the larger wheels and most of you responded that you put on moton shocks and must of changed your springs what rating did you apply and what factors came into play .I would appreciate your advise.THANKS :confused:
Viper X
Yelloh,
Spring rates depend on intended usage. Moton Club sports with 500 front and 750 rear seems to be a good compromise for occasional track use / mostly street. Lighter for street only.
You can go higher with spring rates, but street ride may be a bit stiff.
Dan
