need to remove the inner wheel wells
C
carl B
United Kingdom
Yes on the rear
Around the outside of the rear fender there are three of these rivets and then some more on the inside??
PhoenixGTS
Phoenix Arizona
I did not know about the rivets. I am thinking about the push clips on the inboard side - like the one right above the battery (there are more on the big portion of the driver's side and the passenger side.
ndvipergtsr
fargo, nd
You need to drill but be careful, the quarter is very easy to chip. I tapped the center in first with a punch to use as a pilot. Jerry
jp
Umea, Sweden.
When you put the inner wheel well back again is it easiest if you heat it up a bit, then the plastic will bend and twist easier. (Wich is needed to get it in place)
Joel
Ireland
BTW, you only need to drill out the front rivet, just behind the door.
Joel
Ireland
Yep, thats it, pull out all the plastic ones, drill out the front steel one, they it just pulls away from the other steel wheel arch ones..........also its easier to grind off the front one.
tbone96
