nos
622r109
liny
hi just installed nos and propane, im getting 600 rwhp, 700 rwtq. people say i should get more torque. does anyone know whats the correct jets for a 05 viper, i brought this kit off a 99 viper and it is an NOS kit not nitrous express. thanks in advance :bonker: :bonker: :bonker: :bonker:
RedEnuf93
Lancaster, PA
The HP and TQ depends on the value of your jets.
Small jets - less HP/TQ
Large jets - more HP/TQ (604HP/782TQ)
I used up to #52 NX jets, custom cutting my own jets to get safely there.
Fuel must be added along the NX.
Regarding propane, I dont have it, so I have no info about it...
Do you know your jet sizes?
622r109
liny
ill have to check them out, i saw on viper alley that btr recmmended 54 nos 40 propane, but i thought that was for n/express kit, maybe there the same. ill have to try those and get back to you. thanks :bonker: :bonker:
i dont think the type of kit matters if it is with the BTR propane setup like you have.
id tell ya to call BTR but i dont think there would be much help since you didnt buy it from HIM directly.
Tom Welch
Blairsville, Georgia
He's right on both counts.........but your torque is about 170-200Ft/Lbs too
low for the HP
Tom
622r109
liny
so ill go with 54/nos and 40/propane and go to colder plugs. thanks fe
llas, ill report back w/results :bonker: :bonker: :bonker:
Tom Welch
AH Hell....Its Christmas time......
Try the following.....
Your jetting is good.
1. Warm the propane bottle to maintain 160 psi.
2. Check the propane solenoid filter to insure that it is
not clogged. (propane can be "dirty")
3. Warm the nitrous bottle to maintain 1050 psi
4. Insure that you are getting propane by spraying the
system with the nitrous bottle OFF. Remove the intake tubes
if neccessary so that you can visually see propane spraying.
5. If you are not certain that propane is flowing, make a dyno
pull with propane only and read the a/f for enrichment. Keep in
mind that propane is a FUEL SOURCE, not a power adder. The
increase in torque is a side benefit of the properties of propane.
6. Check tire pressure, the rear tires should be set to the
stock tire pressure of 29 psi. Drag radials and slicks may reduce
dyno measured torque.
MOST IMPORTANT ITEM.....................
Start the dyno pull at 2800 RPM and terminate it at 5000 rpm max!
Starting a dyno pull above 3200 rpm will show a drastic reduction in
torque as peak torque happens at or before 3200 rpm on most stock
type Vipers.
Good luck
If it still does not make at least 800-900 ft/lbs of torque, give
me a call.
622r109
liny
tom your a real gentleman, and merry christmas to you and your family.GARY :bonker: :bonker: :bonker: :bonker:
622r109
liny
you are right, im using hoosier a6 race tires on rear,with 24 lbs, great hookup but could be reason for low tourqe readings. i can lauch in first at 3500 rpms when i warm them up with nos/propane on,man this car rocks. :eek: :eek: :eek:
Snakenrooter
