Oil Pan Question
Black Moon
Knoxville, TN
I just removed the oil pan from my 03 and see that it has a swing arm and windage tray. Is this a comp. coupe pan or is this stock?
Also, were ARP bolts used internally in 03?
Thanks all.
Sal
redtanrt10
Dana Point CA
Probably, stock. Stock pans have a windage tray and a swing arm, the swing arm only moves one way.
Here is Viper Speciality's "swing arm" that is similar to the comp coupe. Take a look and compare to your's.
Viper Specialty Performance
B
Black Moon
Knoxville, TN
Thanks for the responses. Yes I'm finally getting off the couch and starting the install.
Swing arms were not stock in 03. It is the VSP pan and arm, also a Mopar Performance PArt.
Cape Coral, FL
Nope, our version and the Mopar Comp Coupe version are completely different. The Mopar version is siblings with the OEM 03-06 pan, and ours is brother to the 08-10 pans.
Yes, Gen-3's all came with ARP-2000 rod bolts from what I can recall.
