Pickle
GTSPOWERED
Ohio
I was wondering what the best way to remove the pickle out of a set of Belenger headers is. Any ideas would hepl.
00prowler
Vernon CT USA
Add a 10 lb pulley to your setup and pickup another 50 RWHP...I have the same setup as you on a 96 GTS minus headers making 620 RWHP...The best 200 bucks you will ever spend...AL
nismobrown
wales, GB
carefully move the pickle side to side until you create metal fatigue and it will break off.I used a jack handle and it does not take that long.
file the rough edge where it has broken away.
watch you do not damage mating surface of the flange where the elbow pipe bolts on .
GTSnake
Motor City
I'd be interested to know if you show any gains when you remove your pickle. I changed from Belangers to B&B because of the pickle.
G
GTSPOWERED
Ohio
I will not be able to give any info on the HP gains from removing the pickle because I just bought a used set of Belangers and am going to remove it before installing them.
GTSnake
Motor City
well at least you can find how much improvement you will gain by just adding the pickleless Belangers.
