Just by curiosity I am wondering what is the real boost with a 5lb pulley on a Roe Supercharger. Unfortunatly I don't have a boost gauge installed. I used the VEC2 logging software to measure the boost with a 5lb pulley. It gave the following average values:
4.3psi at 2000rpm
7.0psi at 5500rpm
Temp: 40F
Elevation: sharp at see level
What is you real boost ? (and configuration)
I am also interested in injector pulse offset on cylinder #10.
4.3psi at 2000rpm
7.0psi at 5500rpm
Temp: 40F
