Rear window seal
Robin747474
United States
Hello, trying to figure the fitment of the rear window seal on my 96rt, have had 3 other vipers but it is the first seal from temple performance, took all excess rubber off clear to the glass first seal ripped during installation ordered another seal it's not close to fitting tried everything go it slippery tried some heat it's just none not even close to the point I'm pushing and it's about to break, have done 3 prior no issues are these seals just a bit bigger hate to trim it down it's still a good half inch off anyone have any pointers thanks
4bangerviperjr
Kokomo Indiana
I had to cut about 3” out of the middle of the one I tried. And even then, with the seal being a full bulb, it didn’t want to go in. As expensive as they are, you’d think it would fit without having to cut it. The other issue is the full bulb, it makes it difficult for it to “sweep backward” like the oem seal when pushing it into the body. I THINK If you were to cut the bulb in half and remove the inboard portion so that it’s just a half bulb, it would fit much better. But I’m not about to spend another $200 to cut it up and find out. Already wasted that much once. In the end, I used a generic glass seal from Amazon for $20 and it’s worked perfectly.
viperkim
St pete
Very common problem. And solution.
Dan Cragin
LA, CA
You need to shorten the replacement seal on a 96 RT
R
Robin747474
United States
Thanks for the advice, you wouldn't happen to have a old pic of that seal you bought would you just in case, I'm really losing my patience with this one, thanks
Go-ran
Toronto
I have to replace mine, but ive been putting it off as its never on the car other than during car washes. Do you have a link for the amazon replacement?
Thank you
ViperFan1
Maryland
I bought a temple seal for my 99 and it never fit. Per their instructions, cut off a bunch of rubber all around, and now there's gaps everywhere. Can't believe they sell that garbage for $180.
