Reduce heat in the engine with the hood gasket away?
Tomas
Åland Islands (Baltic Sea Hawaii), FINLAND
Hello everyone
Has someone take the small hood rubber gasket away to reduce heat under the hood?
I did that on my supercharged vette on the engine starts to run a little bit cooler and its also cooler in the engine compartment
regards
Tomas
RT/ED
Commerce , MI
This suggestion was previously suggested by one of the members. I went ahead and removed mine. It is very easy to remove without damaging the rubber or the plastic pins that hold it in. I pulled the gasket away from the pins and then carefully removed the pins with a pliers and reinserted them into the gasket. Based on my observations, it only makes sense that removing the gasket will allow heat to escape the engine compartment. :usa:
HavikPerformance
