Well like many other owners of the Roe supercharger I have had my drivability problems. Until today this morning prior to a VCA meeting I went to Sean's shop and we removed the protype VEC 2 from Sean's car and put it on mine all of which took less than 30 minutes easy install. We used the same program that Sean had used on his car and upon intial startup of my car I could already tell a difference without even driving the car. As soon as I drove even below 20 mph I could tell adifference also, the car was much more smooth. We then proceeded to get on the highway and unlike before when I had no detonation until 5600 or above I now had it under light throttle application around 2500 to 2700 area huh. Well no problem we pulled over Sean plugged the laptop in adjusted some timing retard and, and like being on pit road the stop was under two minutes and back on the road. Now at the same speed and engine rpm now detonation, and gobs more low end torque, but at my original problem area we had some detonation again, so back to pit road and I think Sean's times as a crew member are getting better under two minutes Sean once again reprogrmamed the VEC 2 and we were on the road again still same tons of power on the low end and all the way through right up to 6000 rpm no detonation. This is a remarkable unit and Sean has done an awesome job with the ability to clean up so many issues with a quick stroke of a key on a laptop and swipe a new card into your VEC 2 I think the possibilities are almost endless. So as the day was coming to an end we headed back to Sean shop so he could take his VEC 2 off my car and put it back on his, he ran inside to open the garage door and I drove off with the VEC 2!! Just kidding. Thanks Sean great job and to everyone else this will make your day when you receive it.
