Roll Bar & Gauge Pod Pics
JimT 99RT
Reno, NV, USA
Here are some pics of the Autoform Roll Bar installed and the Elite Gauge Pod. I used a heat gun at 600 Degrees to make the Gauge pod fit better and form it to the pillar on my RT/10. I installed an Autometer Boost/Vacuum gauge and Fuel pressure gauge in the Pod.
papabear
Does that roll bar fit under the autoform hardtop? Any problems with putting on taking off the top? Just curious.
J
JimT 99RT
Reno, NV, USA
I bought the gauges with electric sending units from Summit Racing; they were about $190 each. The Vacuum gauge has memory and will keep the peak reading and also has a warning indicator that is manually set. There is no problem putting the Hard and Soft tops on. The hardest part of the Roll Bar install was getting the new panel piece to fit, I ended up having to file it down in several places to get it to fit right, I ended up taking about ¾ of an inch off of each of the trim pieces that fit around the left and right bar ends.
