Service Engine Soon light came on!
Jerry Scott[CO]
Morrison, CO, USA
This could be any number of problems. The most common being the O2 sensors in the exhaust. If you have an aftermarket exhaust, they could be burned out or a bad connection. It's best to take it to a dealer and have them check it with their computer, which will locate the problem in about 2 minutes.
Quantico, VA
Also if I've noticed it you run STRIGHT race gas sometimes the O2 sensors get a "hazed". If you have this may be the case you need to run just 93 for a while and that should clear it up, nor would I run stright race gas in there again, I do half/half if anything.
regards
