RSI SR S/C 1000 Performance Package complete with:
RSI 1.75 Stainless Steel Headers with 5 to 1 racing merge collectors,3 inch Stainless Steel Exhaust with Stainless Steel Mufflers and Cats, 02 Simulators, and Stainless Steel Clamps; RSI 520 CI Stroker with JE pistons, JE rings, Manley Pro Series connecting rods, Coated Main and Rod bearings, Professionally machined, blueprinted, balanced, and assembled; RSI CNC Ported cylinder heads with 2.02 and 1.60 Stainless Steel valves, Full bronze guides, Heavy duty valve springs, Titanium retainers, Full machined locks, ARP head studs, Custom Ground Camshaft, Upgraded lifters,1.7 T&D roller rockers, One piece hardened pushrods, Billet aluminum valve cover spacers, Lightweight flywheel; Polished Paxton NOVI 2000, Air to water aftercooler, Billet aluminum supercharger brackets, Billet aluminum blower and crankshaft pulleys, Bypass valve, Properly sized fuel injectors, High volume fuel pump, 2 high volume fuel filters, Upgraded fuel lines with Aeroquip fittings, Adjustable fuel pressure regulator, Polished aluminum air inlet, Programmable engine management system, All necessary gaskets, fluids, and hardware, Dyno tuning, RSI custom floor mats, RSI SR S/C 1000 badges, Mobil 1 oil and filter, Installed
RSI Viper Throttle Body Injected Nitrous System;
Dual nozzles, nitrous and fuel solenoids, stainless steel braided fuel and nitrous lines, solenoid mounting plates, electronic TPS switch, Carbon fiber center console mounting plate with electric nitrous gauge, activation switch, purge switch, RPM activation module, RSI Bottle mounts, heater with transducer, Purge, 10lb bottle, 100 to 300 adjustability, Installed
RSI Aftercooler Nitrous System;
Polished aluminum spray bars, nitrous solenoid, fittings, Stainless steel braided nitrous line, 10lb nitrous bottle, RSI bottle brackets, Activation switch, Installed
I think I need a clutch,,,,,,,,,,
Here's an updated,
