superchargers, sparkplugs, and intercoolers
fe155
San Diego,ca
Interesting info under "tech" section in www.superchargersonline.com. I cant seem to keep the check engine light from sending misfire codes , seems to always happen under load and above 3000 rpm's . In the section under "tech" - the skinny about spark plugs- it says platinum tip plugs have to small a surface area for supercharged cars with richer fuel mixtures and causes spark plug blowout . It also suggests a smaller gap than usual. And to try a plug 2 steps cooler first . Anyway check out the article. And it says that intercooling with 5 to 6 #s of boost is a waste and actually loses #s by the time it gets through the cooler. Check out this article also .
