Tire size for HRE wheels?
Jonne
Nutley, NJ
I have 18x10 and 19x13.5 HRE's wheels for my SRT-10 and need to get some tires to replace the run flats. What recommendations you guys have, and should I forget the TPMS sensor for all? I'm planning to lower the car with Eibach springs (maybe caps too). Should I go wider in the front and back than the stock size (275/345) or will I get rubbing problem? Doing street driving 99.99%
Wheels 18x10, 19x13.5
I found these options:
Pirelli PZero Rosso
F 275/35/18 , 295/35/18, 295/30/18
R 355/25/19
PS2
F 275/35/18, (no 295/35/18 C1 viper type for the front)
R 345/30/19
Nitto Invo
F 275/35/18, 295/35/18
R 345/30/19
Any thoughts, other sizes/brands I may be missing?
Thanks,
JK :usa:
Ricketts
Fayetteville NC
I'd go Invo's have them on my GTS and love them. The 275's are too skinny for the fronts if they are 12 inch wide wheels, the 295's would be a minimum. If the fronts are 12's I'd try and find some 305's atleast, maybe some of the track rats will chime in about fronts that wide. My fronts are 10" wide with 285's. Go with 345/30/19's for the rear
J
Jonne
Nutley, NJ
My mistake. The fronts are 18x10 so 275 sould be ok.
Nine Ball
Houston, TX
I prefer to run 285s on front (10" wheel) and 345s on the rear. Are you sure your wheels are 13.5? HRE usually specs out 12.5 for the Viper rears. That is what my HRE wheels are.
