RobZilla
I am not trying to bring back any old debates as there are countless threads on this topic. I searched through most of them and don't claim to be knowledgeable at all. In fact the only thing I learned is that my transmission probably has a non recommended fluid in it, and I'm sure I'm not the only one.
Thus the rise of the "Transmission Fluid Redux." I pulled the following product sheets and linked them here for easy reference:
MOBIL 1 SYNTHETIC ATF: Mobil 1 Synthetic ATF
ROYAL PURPLE SYNCROMAX: Royal Purple Manual Transmission Fluid <--- click product sheet
ROYAL PURPLE MAX ATF: Royal Purple Transmission Fluid <--- click product sheet
PENNZOIL SYNCROMESH: http://www.pennzoil.com/documents/Synchromesh Manual Trans Fluid.pdf
CASTROL ATF+4: http://www.castrol.com/liveassets/b...G/local_assets/downloads/p,q/pds_ATFPlus4.pdf
REDLINE SYNTHETIC OIL for transmission - Red Line Synthetic Oil - Gear Oil for Manual Transmissions - MT-90 75W90 GL-4 Gear Oil
MOPAR 75w90 - needs data sheet link
Interestingly enough I could not find Castrol Synorq LT nor a data sheet after a painful search.
I assume that any of the above could be used but I am searching for the best possible option keeping in mind the heat of the Florida summers.
My conclusion:
Based on my research , and as per Tom, our T56's should not be using a GL-5 which is what the Mobil 1 75w90 is. If the Mopar factory fill is the equivalent then wouldn't it be GL-5 also? So one should pick from the above listed options... thoughts.
My conclusion:
