Hey guys, quick question
On my VEC2, i have the DB9 connection.
What i want to do, is to bring the cable in the cabin so i can tune with the laptop in the car without having to pass a wire by the window.
Here is my question, should i install a new extension cable with 2 DB9 connection at each end or should i just cut the wires between the VEC and the connector and lengthen the wires to the cabin. What have you guys done?
Also, about the ground wire on the connector, which bolt did you attach it to? (Andras, this one's for you )
Should i use a ground in the cabin the closest possible to my Laptop connection?
