Does anyone know what(name,model#) Brembo calipers and rotors, the GTS-R had? The calipers were gold with brembo letters in red. I also believe that they were the forged monoblocks? Please correct me if I am wrong. Thank you
I am not too sure on what the GTS-R had, but, I have 6 piston monoblock calipers and a 4 piston rear. If you want I can send the part numbers to you via e-mail.
It was supposedly the closest to full motorsports caliper offered in a street application. Brembo's words....not mine.
I think you are talking about Brembo GTR's, coudl be wrong but that sounds like the application, although it sounds like they are only 4 or 8 piston. I have these on my car
Features of the GTR High Performance Brake System include:
Brembo GTR FAQ
- Brembo forged 4 or 8 piston racing calipers with sequentially sized pistons (lighter and slimmer profile than standard Brembo GT calipers). Some GTR calipers are 1-piece monoblock construction while some are 2-piece, depending on application.
- Brembo ventilated titanium piston inserts to form an additional heat barrier (most GTR calipers, not all)
- Brembo two piece "floating" hat and rotor assemblies reduce unsprung weight and dissipate heat faster
- Brembo slotted and directionally vented two piece rotors
- DOT and TUV certified Goodridge stainless steel brake lines; guaranteed for life
- Brembo high performance brake pads; up to 4 per caliper; available in street or race compounds
- Brembo "floating" anti-rattle rotor hardware developed by Brembo for the McLaren F1 road car
- Brembo billet brackets with aircraft quality hardware
Q. What's the difference between a Brembo GTR caliper and Brembo GT caliper?
A. There are a few differences that distinguish a GTR from a GT caliper.
- GTR calipers are forged, GT calipers are cast. Because of this manufacturing difference, the GTR caliper can be made to have a slimmer profile, allowing it to clear more wheels. This difference also makes the GTR caliper lighter, stronger and stiffer.
- Most GTR calipers have ventilated, titanium pistons, while GT calipers have aluminum pistons.
- GTR calipers are only available in the goldish-anodizing with red machined logo. Powdercoating the caiper would retain heat. Standard Brembo GT calipers are the ones typically powdercoated (usually red, black, silver, yellow, etc.)
Brembo GTR FAQ
