Joseph Dell
Strange thing has happened recently... when the car is warmed up (not when it is starting cool), the following occurs:
1 - car won't idle. it just drops to 0 rpm and dies. I could be coming off of a highway ramp and when I reach the end of the ramp, the car will die if I take it out of gear.
2 - when I am in BETWEEN gears, the car will die. If I put the car in NEUTRAL, the RPM will drop to ZERO and the car will die.
In both cases, it starts right back up but own't idle unless I let the car cool.
It did this a few times, and never threw a code. Today, after driving for 30 minutes, when I was doing the "keep-foot-on-gas-while-using-hand-brake-to-slow-down" trick, the car threw a code: P0340 - Camshaft position Sensor A Bank 1 circuit malfunction.
Does anyone a) know what this code means b) how to fix it (I alrady cleared it), and c) could the code be related to the idle / car die-ing problem?
Thanks in advance for your help!!!!
JD
JD
