08 AutoX Video
john2456
How did you do?? I have seen Miatas beat Z06s,Vipers etc,, since they are so lite and nimble and of coarse capability of driver.
L
lmcgrew79
Hurricane, WV
zo6's running about 33.5 to 34 something on hoosier a6's. I was running right at 36 seconds. Stock PS2s. Tires can bring about 2-3 seconds off your times. So its hard to tell. The viper is a lil difficult on autocross with the torque. It will understeer on tight corners. I lil throttle and it steers better, more throttle you get power oversteer. Im still learning the car. I think with tires, and camber adjustment it would be competitive. But like you said so is a miata. If anything you get a tremendous idea of how the car handles, and the back will steep out pretty quick.
john2456
Imcgrew, Sounds like you are having a lot of fun and on a learning curve with the Viper. I suspect it is MUCH harder to drive autoX than most cars. In a Miata,you just press the go pedal to the floor and steer around cones. Can't do that with our Viper !!!!!!!!
zeeshan_k24
