Has anyone noticed a backfire when shifting in the higher rpm range ???
Thanks, in advance
Thanks, in advance
Dear Steve,
I think you may have had the famed Torquethrust Flatulence release. This is caused by the tremedous G Forces caused by 505 cubic inches of V10 muscle. When shifting at high rpms the backward thrust , and consequential hard whack of the cerebellum upon the seat back causes the sphincter sensor in your cranium to release neurons ( often accompanied with a verbal sensory movement stating, "This thing is faster-n-shi*" ) causing said backfire.So when you ask if this depends on the speed of the car, my recommendation is to just wear Depends.
Tech Bulletin #Farty Four
