2013 flywheel
MTGTS
Orlando, Fl
Why not just get one of the chromoly's for the same price as the aluminum's? Still weighs 10lbs less and chromoly > aluminum. You also don't have to wait for a part that's not even available
C
Chuck 98 RT/10
tampa, fl USA
After market flywheels can develop issues with the starter. I figure OEM has been tested thoroughly enough. Do you have chromoly Matt? If so, I assume you haven't had any issues. Does it have steel gear teeth?
MTGTS
Orlando, Fl
Camfab
SoCal
I agree with Matt, DC Performance carries them as well. If I'm not mistaken the Cromoly flywheel I saw at DC was one piece. I believe the photo in the link provided is actually a pic of an Aluminum Flywheel.
MTGTS
Orlando, Fl
yeah, I don't think the pic is correct as mine doesn't look like that
DanielR
The flywheel in the photo from the link is aluminum with (steel I think) inserts for the clutch surface.
The Chromoly flywheel from DC Performance is one piece. That is the one I installed when I did my clutch.
C
Chuck 98 RT/10
tampa, fl USA
The two issues I've read about are the teeth not be cut correctly and messing up the starter, and also read once where the ring separated from the flywheel.
