OrthoD
I want to change the gears on my SRT10 coupe. Any suggestions on which gear to go with?
I have 3.55 and it seems perfect to me. 3.73 may be a little bit too much.
The lower gears will mean an added shift and more difficult for a good hole shot.
So did you need speedo/odo calibration?? I've been hearing both sides.
I've been considering gears but the thought of calibration boxes scares me... it is a MAJOR pain in the butt...
Who do you guys think make the best 3.55 gear set for the best price?
I have run all of the gear sets below at various power levels. IMHO;
3.55's work well with stock Gen III tires.
3.45's work well with stock Gen II tires.
3.33's work well too if you can find them.
3.07's are best for higher power levels, i.e. Paxtons, etc. and work well at road racing events.
3.73's are too low for Viper, in my opinion.
If you are mostly stock, i.e. headers, intake and a tune, you won't have any real traction issues with either 3.33, 3.45 or 3.55 gear sets, especially with sticky tires.
Dana seems to make the best gear set and sell it as a Mopar part.
No speedo recalibration needed, the speed signal comes from the wheel speed sensors as stated above. Your speedo will be off slightly if you change tire sizes from stock.
Call Unitrax for parts. They are the best.
Good luck,
Dan
