96 GTS FAILED SMOG TEST
Gavin
Monterey, Ca, USA
Passed all items except hydrocarbons at idle - 100 units permitted - measured 446 units.
Potential causes as described by smog mechanic:
Bad plug wires
Air leak
Bad Catalytic converter
Bad O2 sensor.
Plug wires were new about a year ago - stock viper part
Intake manifold gasket replaced two years ago (warranty) car idles perfect.
One O2 sensor replaced under warranty - I guess this leaves three others that could be bad?
Any other ideas as to the cause
Gavin
striker79
alta loma
This may sound stupid but did you drive it around to let it warm up.Other than that unless you added a adjustable fuel regulator check your plugs and wire's possible fuel filter clogged or air cleaner.
G
Gavin
Monterey, Ca, USA
Thanks guys
Will pull plugs, air and fuel filters - I know the K&N air filter is due for a good cleaning.
Will post outcome as I know someone else is going to run into this too!
Dion Fisher
renton, wa
Gavin,
I just had to replace both forward O2 sensors on my '96 the left was shot and the right was just about flatlined.. Check them out!
BarryLB
